Miktoik PPPOE erroe
authentication failed: peer didn't respond to CHAP challenge,
anyone know the solution ??
Any info in log except this ?
error mentioned above shows in log
what is the authentication type you set?
Does the server support CHAP ?
yes i am using mikrotik
its support chap
make sure the physics interface is ok then
try this
interface/pppoe-client/ monitor pppoe-out1
/log print where topics=pppoe
PPPOE-Out1 is my pppoe out interface ??
@MikroTik] > /log print where topics=pppoe
@MikroTik] >
yes
if no information is given try to set it to “~pppoe”
[root@MikroTik] > interface/pppoe-client/ monitor pppoe-out1
no such item
[root@MikroTik] > interface/pppoe-client/ monitor OLT-USERS-301
no such item
[root@MikroTik] >
i ma not using pppoe client
i am using static ip for wan
press TAB and have a loook what interface you have
there should be something if the interface name there
do duration interval numbers
i have this
Post your complete configuration, instructions here:
