Miktorik Mesh WDS wont disconnect low signal links.
I have a Mesh setup deployed with 3 nodes. Node A is the gateway, B is an intermediate node and C is a node farther away. Node C can see node B at -71 and it also can see Node A, the gateway at -84. Because the path directly from C to A is a 1 hop path verses going from C through B to A, a 2 hop path, C is sending all its data via the shorter crappy path and A is sending data to C the same way. This is resulting in slow connections for clients connected to node C.
I have set the access list signal level field to reject connections with a signal level of -80 or worse but this setting is
being ignored and the WDS is being connected anyway.
Am I missing something here or is this broken in 4.6?
for WDS link creating you should use Connect list instead of Access list.
That didnt do it.
I put an entry in the connect list for the mac in question, on both ends, the mac of the opposite side.
I set the signal level to -75..120 and the connection dropped for an instant and came right back.
I even unchecked the ‘connect’ box to no effect.
Next suggestion please…
enable the debug logs ‘wireless,debug’ and check if it looks through the connect list.
Also If you use the connect-list, then I would suggest to disable the default-authentication on the AP.
