Miktrotik and UBNT VLAN compatibility
Guys,
I’m about to implement VLAN in my network and i’m looking for advice or suggestion for my setup.
my first question is, is there compability issue if i enable VLAN feature in miktrotik router and Loco M2 or NanoStation M2 VLAN feature in customer side and will it work? see my diagram below.
Regards,
Alex
Iam running an SXT whit several vlan on the ethernet port that are connected to an ubiquity switch whit no problems.
Thank you your reply.
I have a question, Do you enable VLAN feature in miktrotik router
my setup is this:
Miktrotik router > Fast ethernet > ptp link > faster ethernet> Airmax omni> Client VLAN ID=100 or 200
Regards,
Alex
I running tagged in mikrotik sxt ethernet - > Ubnt switch and untagged from ubnt switch to user.
Thank you. it’s clear to me now.
