Is it possible to use the “MIMO A” and/or “MIMO B” .. perhaps with an automatic algorithm?
“MIMO A” uses the two polarizations to send the same data doubling the chances that the data reaches its destination (for CPE with low signal or long-distance)
“MIMO B” uses the two polarizations to send more data (CPE nearby AP that require more bandwidth or with good signal).
There is a possibility of doing it manually? And automatically?
Bye
