MIMO AP x Client - chain 1 x 0
Hello guys,
I would like to ask you if it does mind that,if you set up MIMO AP and you connect vertical antena to chain 0 and horizontal to chain 1.
Then you set up antena at client where you put vertical to chain 1 and horizontal to chain 0.
Will this setup work correctly or horizontal on one side will connect to vertical on the other side and vice versa :slight_smile:
Thx a lot for your reply
Should work fine.
