MIMO with Mikrotik
hi guys!!!
which Mikrotik products are capable of MIMO??
help will be highly appreciated.
-sid
All RouterBOARDs support MIMO wireless cards (802.11n).
As for the cards themselves, go to http://www.routerboard.com/?group_id=13 and then select 802.11n on the left
hi,
thanks for the reply.
but what about antenna connectors? does MIMO need 2 connectors.
also do you offer it on the RB711 kind of boards?
RB711 has 802.11n card on it, but only one connector. 802.11n doesn’t need two connectors, but usually works slightly better with two. RB711 has only one connector.
Normis…
is the RB711 can just solder the cat 5 cable to the console pin, and it can be work when connect to the hyper terminal as usual?
another thing is, it’s really can achieve up to 95Mbps with only single chain?
in India it is very difficult to get a decent 24dbi MIMO Antenna (Flat) with enclosure.
now with mikrotik boards i want to make some ’ Made For Mikrotik ’ products with my brand but it is getting extremely difficult on the ‘Enclosure’ issue.
how would MIMO antennas work if compared to Dual-Polarized antennas?
