mini-PCIe slot not working???
Hi
Can someone confirm to me if there is a problem with a mini-PCIe slot on my Mikrotik routerboard?
Am I right in thinking that the device in the slot should show when issuing “system resource usb print” even if the cards firmware is not the correct version? I have tried two different mini-PCIe cards and both show nothing.
Kind Regards,
Hello timmay2,
what kind of RouterBoard you are using?
Ah ha!
"Hello,
Please go into the System Routerboard USB section and choose the type Mini-pcie and
then the modem should be recognized.
Regards,
Uldis"
Thanks Uldis! This fixed it and LTE modem on the mini-PCIe slot was detected.
