Minimum license to work as repeater?
I have an ap setup with a routerboard with level 4 and know i would like to put a repeater under a distance but i only have a rb411 with level 3 license. can i do anything to this work as repeater?
or what is minimum license to put this working as repeater?
thanks
licence 3 is enough to build bridge connection… avialable only bridge mode
but in bridge mode i can repeat signal?
Regards
anyone can clarify me this?
Regards
Hi
Level 3 only allows to create ptp links, so you can’t repeat wireless signal, describe scenario for more clarity
Regards
Central with routerboard with level 4 with ap bridge.
Now would like to extend range and repeat signal and have another rb411 but only have level 3 inside.
Any ideias?
hi,
so you have an ap in ap-bridge to repeat this signal you need an level 4 license in to configure wds
hope this helps
regards
so need to upgrade my license. and after just setup as ap with wds? or wich way to configure?
Regards
I’m afraid you will have to get another 411 with level 4 for more info check here http://wiki.mikrotik.com/wiki/All_about_licenses#Change_license_Level
If it will only be 2 aps, you can go for wds, just remember that the wds links will half your link speed, as a tip for more info on that check wiki
regards
in can buy the level 4 just would loose the level 3 license right?
Also for not be half speed how can i setup to repeat with full speed?
thanks
I have just pointed the wds behavior cause it should be mentioned depending on your circumstances and what are you offering to the customers/users and what your bb speed is it may be irrelevant cause the links will deliver enough speed for your needs
there are few ways of doing it
  • creating a back bone with dual radio card solution possibly even 5ghz, depending what kind of bandwidth you need
  • connecting a bridge to your firs ip and setting an ap feed from the bridge (that would be the cheapest option i would think)
hope it helps, regards
