Hi All,
I have a Mini PCI Card (R52) on my RB333. however there are 2 connectors where i can plug in the antenna?!?
Where shold I plug the anyenna in and where is the difference between those two?
Thanks,
Chris
Hi All,
Thanks,
Chris
Greetings!
If the R52 is like the R52H, then ant-a (default setting) will be labeled as “main”. On the R52H, it is the left u-fl connector.
mhh.. one says “Main” and the othet Aux?!?
