Can someone tell me what minipci has compatiblity with routerboard 411A? No Senao 8602, no ar5211, no prisma based…
I just bouth one with an ar5416 chipset and the RB can see it. I can’t believe it!
An ar7130 with an ar5416 that don’t understand eachother. That’s a joke.
Thanks in advance.
5416 chipset is not supported by the RouterOS yet.
What mini-pci can have funcionality with RB411A a part from those of Mikrotik R52 and R52H (I supose)? Please tell me model and company. And the second question: when will appear RouterOs v4. (or another version) with compatibility with 802.11N? Who knows it?
Thanks a lot.
as you say R52 and R52H can work with RB411A,(they are equipped with RB411A for some orders), also i test the SR5 with the 411, its from http://www.ubnt.com. this is what i know.
regards
Thanks for your recommendation, but I search for someone that could work on 2,4GHz. Do you Know others ones? Does it means that any minipci with atheros 5213 has fully compatibility with RB411A? The other compatible chipset is AR5414 (those of mikrotik 52 and 52H)?
Tell me brand and model, please.
Thanks for your help and time.
CM9, Compex WL54AG
In order of power requirements…
CM9
R52
R52H
XR2
That should do it for you - all these cards have long history of performing very well and work nicely.
Scott
Thanks a lot to everybody.
Could be a kind of repository where people ups the cards (minipci) that work with every routerboard? That may help some of us that don’t know much.
Xevi.
