I have just discovered the world of MIPS and have an RB450G on its way.
I know the acronym ‘MIPS’, but what do the ‘BE’ and ‘LE’ architecture suffixes (‘MIPS-BE’, ‘MIPS-LE’) mean?
Thanks,
Colin
Thanks,
Colin
BE=Big Endian
LE=Little Endian
Some more info on endianness.
LE - Little Endian
BE - Big Endian
For you it means nothing. RouterBOARDs come with different CPU types, MIPS-LE and MIPS-BE. All devices in RB4XX series are BE. You can check on download page, when you select a model, it will display the type next to the selection.
Thanks to you both.
Colin
