Mirror IDE disk
I need to know the way to work with Mikrotik Ver 2.28 using two IDE disk working in a mirroring configuration.
Do I need an especial hardware ?
Best Regards.
I’m guessing you would need a hardware raid so that Mikrotik doesn’t see 2 disks. I have no clue what will happen if one disk fails and you replace it - will the license still stick to the same pair?
Sam
