Mirror port on RB750?
How do I set up a port mirroring on the RB750?
I’d like to mirror all traffic on port 2 to port 5. However when I try to set it up I get “all-port-switch not supported on this board” and similar error messages.
This is because of the bug in Winbox. It will be fixed in next v4.2 version of RouterOS. For now you can configure it using command line interface:
/interface ethernet switch set numbers=0 mirror-source=ether2 mirror-target=ether5
Thanks!
port mirroring doesnt work,can you tell me why ?
i have RB750
switch:
NAME TYPE MIRROR-SOURCE MIRROR-TARGET SWITCH-ALL-PORTS
0 switch1 Atheros-7240 ether5_uplink ether4_elko_monitoring
bridge ports:
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether2_server_ftp bridge1 0x80 10 none
1 ether5_uplink bridge1 0x80 10 none
2 ether4_elko_monitoring bridge1 0x80 10 none
switch ports:
NAME SWITCH VLAN-MODE
0 ether2_server_ftp switch1 fallback
1 ether3_najomnici switch1 fallback
2 ether4_elko_monitoring switch1 fallback
3 ether5_uplink switch1 fallback
