Mirroring port on CCR1009
I'm looking how to create mirroring ports on CCR1009.
ccr1009 series - Atheros8327 (ether1-ether4)
Is there any documentation or example to do a mirror between ether1 and ether2 for example ?
This is what I have now:
[admin@RC-PointCA] /interface ethernet switch> print
Flags: I - invalid
NAME TYPE MIRROR-SOURCE MIRROR-TARGET SWITCH-ALL-PORTS
0 switch1 Atheros-8327 eth4-slave eth3-slave
How to change mirroring config?
YM
I found the info … not easy to find but for those who are looking for mirroring only with compatible chip, here is the command:
/interface ethernet switch set numbers=0 mirror-source=eth2 mirror-target=eth1
To check it: /interface ethernet switch print
That’s it!
PS: Works on CCR1009-8G-1S+ and v.6.19
YM
