Guest VLAN Isolation:
Reading articles and posts, it's recommended to set default-forwarding to no and add a firewall rule. My testing seems to indicate that this is redundant. Is this correct?
/interface wireless
add default-forwarding=no ...
add action=drop chain=forward in-interface=vlan-guest out-interface-list=!WAN
DNS
What is the correct way to set up DNS on client network devices (switches, aps)? Do you leave it empty until you're ready to upgrade? Point it toward the router? Create static entries?
Router
/ip dns set allow-remote-requests=yes servers=...
Switch
/ip dns servers=192.168.99.1
Limit wireless device to certain SSIDs
This is dumb and not a MT issue. My Amazon Alexa devices want to keep jumping networks and deleting the network settings on Amazon's site does not seem to work. So I want to limit Alexa to interfaces: wlan-2g-iot & wlan-5g-iot. But I couldn't figure out a more direct way of saying that other than rejecting Alexa on the networks it was trying to jump to, ending up with three rules for each of 10 devices. Is there a better way, more direct way?
add authentication=no interface=wlan-2g mac-address=74:E2:0C:A2:49:D5
add authentication=no interface=wlan-2g-nest mac-address=74:E2:0C:A2:49:D5
add authentication=no interface=wlan-5g mac-address=74:E2:0C:A2:49:D5
Samba
Why are there duplicates in these (unused) sections in the default config?
/ip smb shares
add comment="default share" directory=/pub name=pub
/ip smb users
add name=guest
add name=guest
NTP
I cannot get NTP client working. I had this setup on my hEX S before upgrading to the rb5009 and implementing a VLAN config. I've tried several time servers and I'm pretty sure I've set it up as I had it before and made a firewall rule to open that port. But my router hangs listening for the remote NTP server and all my client network devices hang listing for the NTP server on the router. What am I getting wrong? Something on the Firewall? That's my biggest weakness currently. I'm pretty sure there's some redundancies and improvements that could be made to my config...
# dec/24/2021 10:08:20 by RouterOS 7.1.1
# software id = SYTB-ZK4C
# model = RB5009UG+S+
# serial number = EC1A0FCC6B92
/system identity
set name=RT1-Office-NR2
set [ find default-name=ether7 ] name=ether7-Access
add admin-mac=DC:2C:6E:47:0F:C0 auto-mac=no name=bridge protocol-mode=none \
vlan-filtering=yes
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether2
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether3
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether4
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether5
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether6
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=ether8 pvid=99
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
/interface bridge vlan
add bridge=bridge tagged=\
bridge,ether2,ether3,ether4,ether5,ether6,sfp-sfpplus1 vlan-ids=99
bridge,ether2,ether3,ether4,ether5,ether6,sfp-sfpplus1 vlan-ids=101
bridge,ether2,ether3,ether4,ether5,ether6,sfp-sfpplus1 vlan-ids=107
bridge,ether2,ether3,ether4,ether5,ether6,sfp-sfpplus1 vlan-ids=119
/interface vlan
add interface=bridge name=vlan-base vlan-id=99
add interface=bridge name=vlan-guest vlan-id=101
add interface=bridge name=vlan-iot vlan-id=107
add interface=bridge name=vlan-security vlan-id=119
add name=WAN
add name=VLAN
add name=BASE
add interface=ether1 list=WAN
add interface=vlan-guest list=VLAN
add interface=vlan-iot list=VLAN
add interface=vlan-base list=BASE
add interface=vlan-base list=VLAN
add interface=ether7-Access list=BASE
add interface=vlan-security list=VLAN
set allow-remote-requests=yes servers=\
1.1.1.3,1.0.0.3,2606:4700:4700::1113,2606:4700:4700::1003 use-doh-server=\
https://family.cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dhcp-client
add address=192.168.99.1/24 interface=vlan-base network=192.168.99.0
add address=192.168.101.1/24 interface=vlan-guest network=192.168.101.0
add address=192.168.107.1/24 interface=vlan-iot network=192.168.107.0
add address=192.168.9.11/24 interface=ether7-Access network=192.168.9.0
add address=192.168.119.1/24 interface=vlan-security network=192.168.119.0
add name=dhcp_pool-base ranges=192.168.99.20-192.168.99.254
add name=dhcp_pool-guest ranges=192.168.101.20-192.168.101.254
add name=dhcp_pool-iot ranges=192.168.107.20-192.168.107.254
add name=dhcp_pool-security ranges=192.168.119.20-192.168.119.254
add address-pool=dhcp_pool-base interface=vlan-base name=dhcp-base
add address-pool=dhcp_pool-guest interface=vlan-guest name=dhcp-guest
add address-pool=dhcp_pool-iot interface=vlan-iot name=dhcp-iot
add address-pool=dhcp_pool-security interface=vlan-security name=\
dhcp-security
add address=192.168.99.0/24 gateway=192.168.99.1
add address=192.168.101.0/24 gateway=192.168.101.1
add address=192.168.107.0/24 gateway=192.168.107.1
add address=192.168.119.0/24 gateway=192.168.119.1
/ip firewall address-list
add address=ec1a0fcc6b92.sn.mynetname.net list=WAN_IP
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow VLAN_BASE" in-interface=\
vlan-base log=yes
add action=accept chain=input comment="Allow LAN NTP queries-UDP" dst-port=\
123 in-interface-list=VLAN log=yes log-prefix=NTP:: protocol=udp
invalid
add action=drop chain=input comment="Drop everything else"
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward comment="defconf: accept established,related" \
"Isolation for wifi guest. Only allow internet." in-interface=vlan-guest \
log=yes out-interface-list=!WAN
add action=accept chain=forward comment="Allow VLAN access Internet" \
connection-state=new in-interface-list=VLAN out-interface-list=WAN
connection-state=invalid
add action=drop chain=forward comment="Drop everything else"
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=\
192.168.99.0/24 src-address=192.168.99.0/24
add action=dst-nat chain=dstnat comment="Port Fwd for Home Assistant" \
dst-address-list=WAN_IP dst-port=8123 protocol=tcp to-addresses=\
192.168.99.10
set discover-interface-list=BASE
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
/ip ssh
set strong-crypto=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
established,related,untracked
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!*2000011
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!*2000011
/system clock
set time-zone-name=America/New_York
/ip cloud
set ddns-enabled=yes
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/system ntp server
set broadcast=yes broadcast-addresses=192.168.99.255 enabled=yes
/system routerboard settings
set cpu-frequency=auto
/ip smb shares
/ip smb users
add name=guest
add name=guest
