PC1—RB750-[ipsec 3des]-RB750–PC2
PC1 to PC2, 1500bytes, udp, 3des ipsec traffic, one way:
65% CPU @ 100kbps
94% CPU @ 150kbps
(ROS4.9)
EDIT: same (lack of) performance on v4.10
65% CPU @ 100kbps
94% CPU @ 150kbps
(ROS4.9)
try to connect PC1 to ether1 and the rest to ether2-5
do not use pc1 to pc2 using ether2-5…
I tested normal internet routing upto 40Mbps with rb750
Hi meno. I think you might have misunderstood as I took a few shortcuts in my diagram. I’m testing throughput over ipsec tunnel between two RB750. Both with factory setup (eth 1 wan, eth2-5 switchport1), firewall disabled. Here’s detailed setup:
PC_1 running btest----[eth5]RB750_A[eth1]—{ipsec tunner established}—[eth1]RB750_B[eth5]----PC_2 running btest
I’m getting abysmal 150kbps (that’s bits per second!) throughput at >90% CPU utilization.
I got u.. it will be poor.. these chip are made for SOHO router but its amplified by RouterOS.. if u want good performance buy at lease RB450G or RB1000 it has ipsec hardware acelerator
FWIW, I have 1 customer w/ RB450Gs at each site with 3des IPSEC over a T1 at each end. Itll saturate the T1 and not max the CPU. IIRC, it was at ~30-40% cpu?
Thanks. I’ve seen other posts quoting 4Mbps of VPN throughput for RB450G so that sounds about right.
Turns out RB750 has issues with port 1. IPSec throughput on other ports is quite good.
Where did you get this information about Port 1 on the RB750? I have an older one with IPSEC latency issues.
