Hi
Is it possible to set in Mikrotik MISO mode?
While MIMO is to double capacity, MISO is to send same data over both polarisations, and whoever is receiving better - will be primary channel, so it will act as polarisation diversity.
Other vendor devices has it, while it cut bandwidth in half, it improves reliability significantly .
you can already select what channel to use for transmit. For example you can set that you will Rx over channel 0 and channel 1 but Tx only over channel 1.
If you meant for some kind of automatic detection, then that is not possible in RouterOS.
For now if i enable both channels for RX and TX, i will get double capacity (channels are bonded), but it should be possible to have SAME data on TX(links are mirrored/duplicating data, as other vendor have on atheros cards), and RX will use best channel, it will improve link margin around 1-2db, capacity will be twice less than MIMO, but especially will improve links where diversity is essential.
Just disable all the speeds over MCS7.
Both chains enabled with only single chain speeds allowed. You get MIMO reliability without using the full speed of it. I’ve got a few out there. Funny to see 104% CCQ.
Seems you are right, MCS 0-7 single stream, but i will try to check later by spectrum analyser, if it is exactly same what i want
