Hi
I’ve just accidentally deleted usb port in system => ports. Serial is still there. How can I restore it ?
Hi
did you try to reboot ?
Yes, many times…
You can always try netinstall
try to unplug and plug the usb device back.
Maybe i havn’t expressed myself quite accurate.
Connected USB devices are being seen eg. pendrive.
But usb port is missed from:
[admin@MikroTik] > port
[admin@MikroTik] /port> print
Flags: I - inactive
# NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
Now there is only serial0 present.
But if you do see connected USB devices, why do you need to see an empty USB port?
I would. It should be there, so yes.
For example to connect a 3g modem.
It will be necessary to pinpoint a serial port in ppp section during creation of ppp connetion.
Now, even when a 3g modem is connected, there is only serial0 (physical rs323 port) present. So it is impossible to send AT commands to it.
But it was there… Since my stupid, accidental action which was a click on that red “minus” icon ![]()
It was not supposed to be there. It being there was the bug, not the opposite ![]()
Ok, but in this case, how can I do a cofiguration of 3g modem? ![]()
Ok, corretion. Since 6.7 usb port has appeared in ppp section.
Sorry
And TNX ![]()
Plug it in, and it should appear.
Is that still the behavior? 6.36rc10 and a USB port that did work no longer shows up. I’ve tried a UPS, an LTE card that did work and a USB flash drive.
