Missing Bad Block counter on CRS devices
I have two CRS326-24G, a CRS317 and a CRS305 and no one in /system/resource/print is reporting Bad Block count.
Is it normal??
e.g.
[admin@MikroTik_CRS317] > system/resource/print
                   uptime: 1d12h48m17s
                  version: 7.13.4 (stable)
               build-time: Feb/07/2024 09:59:26
         factory-software: 6.44.6
              free-memory: 929.4MiB
             total-memory: 1024.0MiB
                      cpu: ARM
                cpu-count: 2
                 cpu-load: 0%
           free-hdd-space: 1112.0KiB
          total-hdd-space: 15.8MiB
  write-sect-since-reboot: 1412
         write-sect-total: 3055183
        architecture-name: arm
               board-name: CRS317-1G-16S+
                 platform: MikroTik
Thank you in advance.
Andrea
Both my CRS317 & CRS305 report bad blocks, but I am still running v6.x on those.
IIRC during early ROS7.x release there were several posts on missing bad blocks counter, but I thought they had been “reintroduced”.
With ROS6.x there was bad-blocks counter as I remember.
Is possible with the 7.x versions they are hidden if the value is 0.0 , as reported in an other post?
I saw some pictures in other post where the counter is present, but IIRC are only routers, no CRS switches.
Anyway, thank you for reply :slight_smile:
