I’m trying to set up CAPsMAN on my router, but I can’t find the menu button in Winbox. I’m quite puzzled by this situation. Any insights or suggestions would be greatly appreciated.
Here’s what I’ve already tried:
I reset the router configuration to default settings.
I did a web search (though I might have missed the answer if it’s out there).
I checked WebFig to see if the menu item was disabled, but it’s not there either.
I downloaded ARM64 Extra packages to potentially install the wireless-cm2 package. However, I couldn’t find it in the zip. Is this package available from a different source? Or is wifiwave2 the replacement for this package?
I also ran the command /interface/wifiwave2/capsman set enabled=yes interfaces=bridgeWiFi, and the print output confirms that it’s enabled with certificates.
My router’s board name is hAP ax^3, and here are the installed packages:
/system package print
0 routeros 7.8
1 wifiwave2 7.8
Thank you for any assistance you can provide.
