Hi
in the past it was possible to configure Ethernet interface to at least some distinct speed values via the winbox/webgui.
This resulted in a bandwidth setting for the interface , not using the queue.
sample see here:
[admin@router01] /interface ethernet> print detail
Flags: X - disabled, R - running, S - slave
0 R name="ether1" default-name="ether1" .......
advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full full-duplex=yes tx-flow-control=off
rx-flow-control=off speed=100Mbps
bandwidth=10M/10M
switch=switch1
Now the possibility is no longer in the GUI. Is this a fault or by intention ?
