Missing frequencies 2467, 2472 MHz?
On my RB112 I can set the frequencies of 2467, 2472 MHz; while on my RB333 these frequencies are missing.
The R52 radio card is the same on both routerboards, I know there are different versions of O.S.: on RB333 I have 3.0rc4, on the other 2.9.35.
What’s wrong?
Thanks.
Your country-settings may be inaccurate on new RB.
Open winbox, wireless, open the wlan-interface, on right-hand side click “Advanced mode”, open the “Wireless”-Tab, choose the right country, “apply”, now you should have the channels mentioned. If not, they may not be allowed in your country ?!?
Sincerly
Schnulch
EDIT:
By the way, upgrade your RB333 to ROS 3.10, You are using an old beta Verision.
