Missing hardware CAD models
From time to time hardware CAD models are not available for products - for example the LtAP LTE7. I usually search GrabCAD etc, but if I can't find then I model myself. Does anyone else do similar and is there a pre-existing channel to which I can add and share my CAD models?
Cheers,
CM.
If you search in this forum, you will find some another drawings with MT devices, you have Visio here: VISIO stencils - #30 by normis, maybe you can convert them to CAD drawings files.
