I have two RB2011iL routers.
Each came with a version 5.x of the firmware. This version does not have the ‘Groups’ section in IPsec, which I need.
I upgraded each to firmware 6.11 via the Packages / Update button. I rebooted each. I went to System / Routerboard and updated the firmware from the original 3.10 to the latest showing 3.12.
I rebooted each again.
Now, one of them shows the Groups option, while the other doesn’t. They both show the same software 6.11 and firmware 3.12. They both show the same “Packages” list items. I am not sure what else to check.
I really like the product but am finding the documentation lacking in these basics. It seems likely I am doing something wrong and there is some configuration problem.
Thanks,
Thomas
