Missing Map after importing xml backup from Dude 3.6
Hi Everyone,
I imported my old dude database.xml 3.6 to 6.36 by following the steps listed here http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/DB_import_export
I can see the list of all the devices, but the network map is empty. Is there a away to recreate the map from my current list of devices?
Or do I need to do anything else before importing the old database?
I’ve seen similar behavior. Try importing xml backup again and check if map is loaded then.
