Missing NIC Driver
I have the 2.8 and 2.9beta1 version of the router.
But 3com and ISA ethernet cards are listed.
I have searched the download section for driver update but none.
Please how can I get drivers for reltek 8139 cards.
Did you do /driver add name to add the appropriate driver?
Brian
Yes, I’ve done that and I only got 4 drivers as listed below:
3C509
Lance
Ne2k-isa
Pc-isa
Any solution?
RTL8139 are in fact PCI chips, did you mean you get one on ISA? Vendor, model number, please?
Any supported PCI cards (including RTL8139-based) are detected automaticaly, on RouterOS since long time ago (but I did not check in 2.9beta1 - try stable version first), so if it is a PCI card, the problem is in hardware (swap PCI ports, try different cards). Consult the Device Driver List for the actual list of supported chipsets:
http://www.mikrotik.com/docs/ros/2.8/guide/driverlist.frameset
