Hello, i today updated my hAP ac2 to routeros 7.1. I went to packages, changed channel to testing. Than I installed updates, and router board firmware. So now I have router OS 7.1 and firmware 7.1.
[admin@MikroTik] > /system/package/print
Columns: NAME, VERSION
When i wanted to install new zero tier package, i found out that in packages i don’t see any package except routeros 7.1. Even when i go to System > Auto Upgrade and I click Download All, it only show error message “Couldn’t perform action - don’t know which is system package (6)”. So how can i install zero tier or another packages in Router OS 7.1 ? Did i something wrong or this is some bug ? Thank you.
I found out how to install manualy package downloaded from mikrotik website. So i was able to install zero tier but still i don’t understand i don’t see packages and i get error when i trie to update packages from router os.
Update procedure inside ROS in principle only works for already installed packages. It never showed list of available packages to choose which one to install, one allways had to manually download extra packages and push the wanted one to router.
Now why it barfs at “download all” … could be because 7.1 is new and might have some bug in package upgrade procedure. And there’s no other version available in v7 to upgrade to so empty answer might trigger some other bug as well …
Thanks for replay. So all packages like wireless, ipv6, security, ppp, ntp and other are part of router os 7 package? Because before i had multiple of this packages installed and now i see only router os7 package. But ipv6, ntp, wireless works just fine even i don’t have packages installed anymore.
