Missing parameter in Bridge setup
Hi there.
I can’t find possibility to set parameter auto-mac=yes/no in winbox.
It can be set in terminal only.
I’m using ROS 6.4…
You can’t see the setting, or it won’t let you change it?
my bad. When you set MAC in GUI, the auto-mac will be changed to yes automaticaly.
