Missing port from arp table ?
I’m using a CSS326-24G-2S+ with SwOS 2.16 and i’m not seeing any port enumerated under the host tab. I’m getting mac addreses, vlan but no ports are listed ?
The port listed is the port name - not the port number. Do you by chance have no name listed on the “Link” page?
Here is one of my CSS326 switches with SwOS 2.16
In the event that the image does not imbed, here is a direct link to it: http://k6ccc.org/Mikrotik/Hosts_listing.png
Ah mannn a feel so stupid, thanks !
Don’t feel stupid. It actually would make sense to use the port number if there is no name. I put names on every port because it helps me remember stuff. Also useful on the VLANs page where the name will show up when you rest the cursor over a checkbox. Helps avoid clicking the wrong box.
