missing post!
a few days ago I made a post asking if anyone had tried the new Tranzeo 900mhz equipment with MT and a SR9, but I can’t find the post anymore… why was my post removed? it was not off topic at all, I wanted to know compatibility between a MT AP with a SR9 and a tranzeo 900 CPE…
I tried it and It wouldnt work, doesnt support sr9 freqs.
how so? the band is not that big… is it a different in the modulation scheme or something of the sorts?
Lets try this again. The amount of threads being removed is getting way past silly! :imp:
Tranzeo is using a customized Zcomax GZ-901 in their 900 products. Customized may mean its been hot-rodded for more power. It uses different centre frequencies than the SR-9s so a Tranzeo will not talk to an SR-9.
You can look up the Tranzeo data on the FCC web site.
If MT can run a GZ-901, we may be able to interact with Tranzeo 900 products.
http://www.zcomax.co.uk/doc/GZ-901.pdf
I intend to get one a give it a try. Its a 5414 (send and receive on 5MHz channels) so may work better than the Sr-9, and so far we’re very, very pleased with the SR-9s running under MT. :smiley:
George
I thought some threads were disappearing..i just figured i read the info else where…
mods: what is the policy on thread removal?
tks
http://forum.mikrotik.com/faq.php
