Missing RouterOS winbox plugins
Hello good day to all, i’m using RB450g with latest version 5.21, my problem is i was not able to login in winbox due to missing routeros winbox plugins. how to deal with this error?
pal
On your computer, delete %appdata%\mikrotik and try again.
Delete all subfolders from ‘%appdata%\mikrotik\winbox’ but don’t delete ‘winbox.cfg’ file.
HTH,
thanks a lot sir for your replies but still the same i was not able to access winbox, is there any other alternative way?
pal
What happens if you try it from a different computer? Does it work from a different computer?
the same did not work and i can not access any more it beeps only once.
pal
The mikrotik BEEPS when you try to access it from Winbox???
