hi
i cant access my router via winbox, i get the error "missing routerOS winbox plugings.
please help
thanks
hi
please help
thanks
Are you using the correct version of Winbox for your router’s OS version? They are a bit fussy about that lately.
i downloaded winbox from mikrotik.com
You are using ROS v6.10 on the router? I usually download the Winbox version from the router I want to connect to.
