Hello everyone.
I have unusual problem with CHR, routerOS is 6.42.3. I have write a script via winbox exactly how is described there:
http://forum.mikrotik.com/t/how-to-auto-reboot-if-remote-ip-down-for-5-minutes/51201/1
Problem is that script is gone after cca 1 hour, there is nothing when I open “scripts” tab, only in “jobs” tab I can find one process.
Why is script missing ?
In log I cant find anything about deleting script.
Did you enable safe mode before creating the script?
No, I have not.
I tested od RB HAPac aprox 20-times and there is no such anomaly.
Jotne
July 18, 2019, 11:16am
4
Can you try another script and see if it stays?
example:
:local test "Hello World"
:put $test
I tried but that script vanished just like my own…
Is there anything in the scheduler?
(we’re just guessing here.. might as well post config /export hide-sensitive or send supout to support)
Nothing in the scheduler, empty like church in saturday night…
I have tried config script like admin and nothing change…
I will post config later.
Jotne
July 19, 2019, 6:23am
8
Try upgrade your RouterOS
