Missing SNMP Entries On hAP ac^3
Hi All,
I have a question about SNMP. I have some Mikrotik devices, and I use Grafana + SNMP Exporter to show some Graphs.
I have just notified that my hAP ac^3 router does not provide oids for wifi registration table. :frowning:
Is it a bug?
Firmware version:
[admin@MikroTikAc3] > /system/routerboard/print
       routerboard: yes
        board-name: hAP ac^3
             model: RBD53iG-5HacD2HnD
     serial-number: **************
     firmware-type: ipq4000
  factory-firmware: 6.47.10
  current-firmware: 7.15.3
  upgrade-firmware: 7.15.3
SNMP Settings:
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/snmp
set enabled=yes
I have another router, a hAP:
       routerboard: yes
        board-name: hAP
             model: RB951Ui-2nD
          revision: r2
     serial-number: F11B0FADC27E
     firmware-type: qca9531L
  factory-firmware: 6.45.9
  current-firmware: 7.14.3
  upgrade-firmware: 7.14.3
Different between the routers:
hAP ac^3
[admin@MikroTikAc3] > /interface/wifi/registration-table/print   <------------ Hit F1
append --
as-value --
brief -- Displays brief description
count-only --
detail -- Displays detailed information
file -- Print the content of the submenu into specific file
follow --
follow-only --
follow-strict --
from -- Interface name or number obtained from print command
interval -- Displays information and refreshes it in selected time interval
proplist -- Names of properties
show-ids --
stats -- Show subset of properties in detailed form
terse -- Show details in compact and machine friendly format
value-list -- Show properties one per line
where --
without-paging -- Displays information in one piece
And the hAP:
[admin@hAP-bedroom] /interface/wireless/registration-table> /interface/wireless/registration-table/print    <--- HIT F1
append --
as-value --
count-only --
follow --
follow-only --
follow-strict --
oid -- print object IDs for SNMP protocol
show-ids --
where --
The hAP povides “oid – print object IDs for SNMP protocol”, but the ac^3 does not.
(I’ve tried snmpwalk without any success.)
Did I miss something?
Thanks a lot,
Janos Vincze
Nope. See http://forum.mikrotik.com/t/wifiwave2-snmp-metrics-missing-hap-ax2/162297/1 - there is workaround to use bridge hosts there, maybe that be a workaround.
Thanks a lot!
This can not solve my problem, but this topic is about the issue I also have.
