This is basic, but I’m sure that I’m missing something. I just got my RB411AR (built in B/G card) with an additional R52Hn card. I’ve got it setup on the network, but am having trouble getting the access points setup.
I’ve followed the tutorial in the Mikrotik Wiki, but at the point where it says to give the interface an IP address, I do and it tells me that the address is invalid… hum? I have the APs setup and can see the SSID from the clients and connect, but am not getting an IP address.
My network:
Internet ↔ Cable Modem ↔ Mikrotik RB450G ↔ Gigabit Switch ↔ RB411AR
The RB450G is my internet router and runs the DHCP server for the network. I have the RB411AR getting a DHCP address from the RB450G (configured as a static DHCP reservation).
What I would like is to run the 411 simply as an access point with two SSID networks. One B/G 2.4GHz and one N 5GHz. I’d also like the IP addresses to still be passed out via DHCP from the main RB540G.
Seems like some thing is not setup to pass traffic from the wireless networks to the ethernet, but I can’t figure it out.
Config from the RB411AR:
# oct/16/2012 23:29:29 by RouterOS 5.6
# software id = 927L-KHZ1
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 \
mac-address=00:0C:42:DF:4F:33 mtu=1500 name=ether1 speed=100Mbps
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default radius-eap-accounting=\
no radius-mac-accounting=no radius-mac-authentication=no \
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
radius-mac-mode=as-username static-algo-0=none static-algo-1=none \
static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" \
static-key-2="" static-key-3="" static-sta-private-algo=none \
static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=\
MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers="" \
wpa-pre-shared-key="" wpa2-pre-shared-key=""
add authentication-types=wpa2-psk group-ciphers=aes-ccm group-key-update=5m \
interim-update=0s management-protection=allowed management-protection-key=\
"" mode=dynamic-keys name=WPA2-N radius-eap-accounting=no \
radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=\
disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none \
static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
static-sta-private-algo=none static-sta-private-key="" static-transmit-key=\
key-0 supplicant-identity="" tls-certificate=none tls-mode=no-certificates \
unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=\
33WaterStreetUnitN
"" mode=dynamic-keys name=WPA2-BG radius-eap-accounting=no \
33WaterStreetUnit*
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 \
antenna-mode=ant-a area="" arp=enabled band=2ghz-b/g basic-rates-a/g=6Mbps \
basic-rates-b=1Mbps bridge-mode=enabled burst-time=disabled channel-width=\
20mhz compression=no country=no_country_set default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=yes \
dfs-mode=none disable-running-check=no disabled=yes disconnect-timeout=3s \
distance=dynamic frame-lifetime=0 frequency=2412 frequency-mode=\
manual-txpower frequency-offset=0 hide-ssid=no hw-fragmentation-threshold=\
disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 \
mac-address=00:0C:42:DF:4F:34 max-station-count=2007 mode=ap-bridge mtu=\
1500 name=wlan1 noise-floor-threshold=default nv2-cell-radius=30 \
nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms \
periodic-calibration=default periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
000C42DF4F34 rate-selection=legacy rate-set=default scan-list=default \
security-profile=default ssid=AccessPoint-BGa station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
wireless-protocol=unspecified wmm-support=disabled
set 1 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
arp=enabled band=5ghz-onlyn basic-rates-a/g=6Mbps basic-rates-b=1Mbps \
bridge-mode=enabled channel-width=20/40mhz-ht-above compression=no country=\
no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic \
frame-lifetime=0 frequency=5180 frequency-mode=manual-txpower \
frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 \
ht-amsdu-threshold=8192 ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,\
mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mc\
s-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0,1 \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
D4:CA:6D:10:3F:AA max-station-count=2007 mode=ap-bridge mtu=1500 name=wlan2 \
noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=\
default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 \
nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=default \
periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
post-2.9.25 radio-name=D4CA6D103FAA rate-selection=legacy rate-set=default \
scan-list=default security-profile=WPA2-N ssid=AccessPoint-N \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 \
status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m \
name=default pfs-group=modp1024
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=\
default use-encryption=default use-mpls=default use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=\
default use-compression=default use-encryption=yes use-mpls=default \
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=\
5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in metric-bgp=\
auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=\
default
/snmp
set contact="" enabled=no engine-id="" location="" trap-target=0.0.0.0 \
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp cpu-frequency=300MHz enable-jumper-reset=yes \
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/user group
add name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web,snif\
f,sensitive,api,!ftp,!write,!policy" skin=default
add name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,password,w\
eb,sniff,sensitive,api,!ftp,!policy" skin=default
add name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,\
password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \
enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:65:62:D0:90:42 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\
no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.88.1/24 comment="default configuration" disabled=yes \
interface=ether1 network=192.168.88.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no host-name=\
MikroWiFi interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=512 servers=172.27.27.1,209.18.47.61
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set wlan1 disabled=yes
set wlan2 disabled=yes
set ether1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 \
max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=\
15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set wlan1 queue=wireless-default
set wlan2 queue=wireless-default
set ether1 queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=EST5EDT
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MikroWiFi
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=172.27.27.1 secondary-ntp=64.90
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-addr
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessio
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set (unknown) disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames filter-
yes interface=all memory-limit=10 memory-scroll=yes only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Thanks for your help!
