Missing thread
Sorry, I couldn’t see any option to PM the Admin, so apologies if I’m breaking a rule.
Yesterday I set up a thread called Interface Wireless Print Q? in the Beginner Basics forum – I can’t see it yet. Has it been refused for some reason?
I don´t you are breaking a rule! And if you are able to PM the admins, they can´t work!
This is a moderated forum and as a beginner your messages, threads and also your comments will be first proofed by
an admin or a moderator.
But what I really think is the following! You where perhaps a little bit jazzed or you was being dither and you
was also, only perhaps I mean, pushing the “cancel” button and not the “Submit” button and now you are searching
your thread and will not find them back.
Ok try it once more again I think we will see then what is going on!
