I have a LAN with 3 ROS devices all with ROS 7.14.1:
1 HAP AC2 acting as Capsman
1 HAP AC2 which acts as CAP
1 MAP which acts as ZIP code
Question, I can’t understand even after reading the Mikrotik wiki-help: I currently use the legacy wireless drivers, if I wanted to use the wifi-qcom-ac driver on the two AC2 HAPs I will also be able to check the MAP with Capsman where only the driver exists legacy wifi?
But forget about using hAP ac2 in such role ... it would have to run both wifi-qcom-ac and wireless drivers (the former for better performance, the later for legacy capsman) ... which is both unsupported (on any device) and impossible on hAP ac2 (due to too small flash storage).
