MK 433 AH + UB5 card with Superchanel licence
I have a problem with this combination. It works only from 5180 - 5825 MHz with or without superchanel licence too. If i try change frequency to 4920 or something like this ot more than 5825 it doesnt work. Where is the problem?
I tryed it with R52H but is is the sama… First RB is in AP Bridge mode and the second is in Station WDS. If i set up the first RB to 4920 MHz frequeny it doesn t work!
PLEASE HELP ME !!!
Try to remove DFS if it’s enabled - helped me when I upgraded to 3.30
Rgds,
Mark
Thanx, but i dont use DFS. I works only if i set up to AB/Bridge mode both RBs. With AP/Bridge to Station WDS it doesnt work
check if on both ends you have superchannel set and in scan list of the client you have entered AP frequency if that is not one of default channels.
