Around a half year ago there was a big problem with compatibility on N platform.
What is new at this time? Is it solved? Becouse from my opinion the best way is to use MK to MK or UBNT to UBNT
actually i have better luck with Mikrotik AP and UBNT CPE using N… not sure why.
Does mikrotik fully support TDMA that is in UBNT Rocket? What is your throughput when you are using mikrotik for AP and Ubnt for client?
TDMA or Nstreme doesnt work when you mix and match.
yes, turn off airmax to get compatibility. you cant use nstreme either.
