MK+Aruba 10GBase-T
There is some problem to connect Mikrotik and HP Aruba with 10GBit copper link.
Mikrotik - CRS312
Aruba - 5400R (J9851A), 1/2.5/5/10GBASE-T module (J9995A)
Patch cord - 6A cat (I changed several them)
Auto Negotiation is off on both sides.
This connection is the only one between these switches, last firmwares.
Connect at 1, 2.5GBit - all ok.
Connect at 5,10GBit have errors:
Mikrotik side log:
01:41:14 interface,info ether1 link up (speed 10G, full duplex)
01:41:15 interface,info ether1 link down
01:41:39 interface,info ether1 link up (speed 10G, full duplex)
01:41:40 interface,info ether1 link down
01:42:03 interface,info ether1 link up (speed 10G, full duplex)
01:42:04 interface,info ether1 link down
Bytes Rx : 0
Bytes Tx : 0
HP side log:
1:41:14 00076 ports: ST1-CMDR: port 1/D5 is now on-line
1:41:14 ports: ST1-CMDR: port 1/D5 is Blocked by STP
1:41:14 ports: ST1-CMDR: port 1/D5 is now off-line
1:41:39 ports: ST1-CMDR: port 1/D5 is now on-line
1:41:39 ports: ST1-CMDR: port 1/D5 is Blocked by STP
1:41:39 ports: ST1-CMDR: port 1/D5 is now off-line
1:42:03 ports: ST1-CMDR: port 1/D5 is now on-line
1:42:03 ports: ST1-CMDR: port 1/D5 is Blocked by STP
1:42:03 ports: ST1-CMDR: port 1/D5 is now off-line
Bytes Rx : 0
Bytes Tx : 6,408
It’s not STP problem, on mikrotik STP is off at all, on HP this port is in EDGE state.
I changed ports on both, disabled L3HW on mikrotik, the same error persists.
MK312 connect with the same 312 by 10GBase-T perfectly,
Aruba connect to other Aruba or Huawei switch perfectly too.
How can I try to fix the situation?
HP being HP.
