MK local auth via radius -> ldap ( ActiveDirectory )
Good day ppl.
I want to have MK’s local users authentication through ActiveDirectory database.
I have configured MK to use AAA which is FreeRADIUS on my Debian machine.
freeradius: FreeRADIUS Version 2.1.10, for host i486-pc-linux-gnu, built on Nov 14 2010 at 20:41:03
I’ve activated ldap module to redirect auth requests to active directory.
But when I’m trying to login I recieve this on radius side
rad_recv: Access-Request packet from host 192.168.71.2 port 46069, id=37, length=106
Service-Type = Login-User
User-Name = “davsharyan”
CHAP-Challenge = 0x9908cb3eaf74bb81ea3ff4ded3bea82c
CHAP-Password = 0x00274c77a53c1495fbc0edc43a26a4ef26
Calling-Station-Id = “192.168.33.115”
NAS-Identifier = “NAS”
NAS-IP-Address = 192.168.71.2
Executing section authorize from file /etc/freeradius/sites-enabled/default
± entering group authorize {…}
++[preprocess] returns ok
[auth_log] expand: /var/log/freeradius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d → /var/log/freeradius/radacct/192.168.71.2/auth-detail-20110703
[auth_log] /var/log/freeradius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d expands to /var/log/freeradius/radacct/192.168.71.2/auth-detail-20110703
[auth_log] expand: %t → Sun Jul 3 06:57:13 2011
++[auth_log] returns ok
[chap] Setting ‘Auth-Type := CHAP’
++[chap] returns ok
++[mschap] returns noop
[suffix] No ‘@’ in User-Name = “davsharyan”, looking up realm NULL
[suffix] No such realm “NULL”
++[suffix] returns noop
[ldap] performing user authorization for davsharyan
[ldap] expand: %{Stripped-User-Name} →
[ldap] … expanding second conditional
[ldap] expand: %{User-Name} → davsharyan
[ldap] expand: (uid=%{%{Stripped-User-Name}:-%{User-Name}}) → (uid=davsharyan)
[ldap] expand: dc=domain,dc=am → dc=domain,dc=am
[ldap] ldap_get_conn: Checking Id: 0
[ldap] ldap_get_conn: Got Id: 0
[ldap] attempting LDAP reconnection
[ldap] (re)connect to 192.168.1.3:389, authentication 0
[ldap] bind as cn=davsharyan,cn=Users,dc=domain,dc=am/password to 192.168.1.3:389
[ldap] waiting for bind result …
[ldap] LDAP login failed: check identity, password settings in ldap section of radiusd.conf
[ldap] (re)connection attempt failed
[ldap] search failed
[ldap] ldap_release_conn: Release Id: 0
++[ldap] returns fail
Using Post-Auth-Type Reject
Executing group from file /etc/freeradius/sites-enabled/default
± entering group REJECT {…}
[attr_filter.access_reject] expand: %{User-Name} → davsharyan
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] returns updated
Delaying reject of request 0 for 2 seconds
Going to the next request
Waking up in 0.9 seconds.
Waiting to send Access-Reject to client NASTest port 46069 - ID: 37
Waking up in 0.6 seconds.
Waking up in 0.3 seconds.
Sending delayed reject for request 0
Sending Access-Reject of id 37 to 192.168.71.2 port 46069
Waking up in 4.9 seconds.
It seems everything is configured properly, but the problem is that AD doesn’t store passwords in clear text ( this is normal )
lines from modules/ldap
#  However, LDAP can be used for authentication ONLY when the
#  Access-Request packet contains a clear-text User-Password
#  attribute.  LDAP authentication will NOT work for any other
#  authentication method.
Is it possible to do some tricks/hacks to get working ??
Here are configs
/etc/freeradius# grep -vE '(^$|#)' radiusd.conf
prefix = /usr
exec_prefix = /usr
sysconfdir = /etc
localstatedir = /var
sbindir = ${exec_prefix}/sbin
logdir = /var/log/freeradius
raddbdir = /etc/freeradius
radacctdir = ${logdir}/radacct
name = freeradius
confdir = ${raddbdir}
run_dir = ${localstatedir}/run/${name}
db_dir = ${raddbdir}
libdir = /usr/lib/freeradius
pidfile = ${run_dir}/${name}.pid
user = freerad
group = freerad
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
listen {
        type = auth
        ipaddr = *
        port = 0
listen {
        ipaddr = *
        port = 0
        type = acct
hostname_lookups = no
allow_core_dumps = no
regular_expressions     = yes
extended_expressions    = yes
log {
        destination = files
        file = ${logdir}/radius.log
        syslog_facility = daemon
        stripped_names = no
        auth = no
        auth_badpass = no
        auth_goodpass = no
checkrad = ${sbindir}/checkrad
security {
        max_attributes = 200
        reject_delay = 2
        status_server = yes
proxy_requests  = no
$INCLUDE clients.conf
thread pool {
        start_servers = 5
        max_servers = 32
        min_spare_servers = 3
        max_spare_servers = 10
        max_requests_per_server = 0
modules {
        $INCLUDE ${confdir}/modules/
        $INCLUDE eap.conf
instantiate {
        exec
        expr
        expiration
        logintime
$INCLUDE policy.conf
$INCLUDE sites-enabled/
/etc/freeradius# grep -vE '(^$|#)' sites-enabled/default
authorize {
        preprocess
        auth_log
        chap
        mschap
        suffix
        ldap {
                notfound = return
        files
        expiration
        logintime
        pap
authenticate {
        Auth-Type PAP {
                pap
        Auth-Type CHAP {
                chap
        Auth-Type MS-CHAP {
                mschap
        pam
        Auth-Type LDAP {
                ldap
        eap
preacct {
        preprocess
        acct_unique
        suffix
        files
accounting {
        detail
        unix
        radutmp
        exec
        attr_filter.accounting_response
session {
        radutmp
post-auth {
        exec
        Post-Auth-Type REJECT {
pre-proxy {
post-proxy {
        eap
/etc/freeradius# grep -vE '(^$|#)' users
DEFAULT Reply-Message = "Barev %{User-Name} axper !"
        Fall-Through = Yes
dav Cleartext-Password := "dav"
    Mikrotik-Group = "remotefull",
    Huntgroup-Name == "mk",
/etc/freeradius# grep -vE '(^$|#)' modules/ldap
ldap {
        server = "192.168.1.3"
        identity = "cn=davsharyan,cn=Users,dc=domain,dc=am"
        password = password
        basedn = "dc=domain,dc=am"
        filter = "(uid=%{%{Stripped-User-Name}:-%{User-Name}})"
        ldap_connections_number = 5
        timeout = 4
        timelimit = 3
        net_timeout = 1
        tls {
                start_tls = no
        dictionary_mapping = ${confdir}/ldap.attrmap
        edir_account_policy_check = no
p.s. all the sensitive information have been changed.
Instead of FreeRADIUS go straight to IAS (or whatever it’s called in 2008+), which is the native in Windows RADIUS server.
Or go to that from FreeRADIUS instead of tapping straight into AD via LDAP.
In the “/ip hotspot profile” section, you can set your “login-by=http-pap”. That sends password in the clear.
“login-by=http-chap” encrypts the password, and the password stored in the RADIUS database must be stored clear text.
I will think on this
I didn’t understand. What do you mean ?
I’m talking about MK’s local authentication and not hotspot :wink:
My bad. I guess you have a real challenge. If there is no way of disabling the http-chap login type, you must enter the passwords in the RADIUS database clear text. :frowning:
The reason is highlighted below.
ADD: There is no way to MD5 decrypt. That is not how this authentication method works.
That CHAP-Challenge entry was the string that was appended to the password at the router, then MD5 hash to that to create the CHAP-Password in the router. That section of the log above is how it is sent.
The FreeRADIUS server will get the user’s clear text password from the database, append the CHAP-Challenge to it, then do an MD5 hash on that, just as the router did. Then the server compares the two ENCRYPTED passwords. If the encrypted passwords match, then Access-Accept. Else Access-Reject. In other words, there is no “MD5_Decrypt”.
Thr FreeRADIUS server uses the same technique to store the passwords encrypted, except with a fixed CHAP-Challenge. As I recall, you could not “read” a user’s encrypted password. You could only “test” it. You enter what you think the password is, and the server will respond with yes or no. Same reason as above.
Thnx pp.
bad badd …
I even cannot use unix module, again, as I understood because MK uses CHAP, but “unix” uses crypt.
Is there any way to have users passwords in encrypted form and not in clear text ?
Thnx
TRJ
