Two CRS326 switches connected to each other with an ISL which transfers several VLANs (let’s say 1,300,400,500), a bridge is created on each switch with all interfaces plugged in.
There is a server, which is connected to both switches, i want it to connect with LACP in MLAG. The server will work in VLAN 300. To configure MLAG, the documentation says to create a bridge, assign it a unique pvid, move ports (peer-ports) and the bond with links to the client (+ mlag_id).
I would not like to modify the current configuration too much (bridge / ISL), so I am looking for information, is it possible to transfer ICCP traffic in an existing configuration?
The most interesting for me is can i use existing bridge to maintain current ISL connection and use it also for port-peer to transport ICCP ? This will simplify topology and also keep hw offload ability,
