Hi all.
I’m new to the Mikrotik universe and I’m trying to configure MLAG with two devices.
I am doing all the steps in the post: https://help.mikrotik.com/docs/display/ROS/Multi-chassis+Link+Aggregation+Group
But when I run the last step in “/interface bridge mlag” to create mlag it shows the message: “not hw offloaded”.
Is this because hw-offloading needs to be disabled?
I tried with this command and the message does not change:
/interface/ethernet/switch set 0 l3-hw-offloading=no
/interface/ethernet/switch/port set [find] l3-hw-offloading=no
Does anyone have any idea what I should do?
thanks
Hi o/,
same with 2x CRS518 and routeros 7.14.1
[admin@CRS02] > /interface/bridge/mlag/print
;;; not hw offloaded
bridge: bridge1
peer-port: bonding1
[admin@CRS02] > /interface/bridge/mlag/monitor
status: disabled
[admin@CRS02] > /interface/ethernet/switch/l3hw-settings/monitor
;;; L3HW is not running
Activating or deactivating hw offloading on the switch chip has no influence on the message. Off should be correct according to the documentation.
I’m not sure what “;;; not hw offloaded” means if off is correct?
The answer is in the first caution box on the documentation page you linked to: “The MLAG is not compatible with L3 hardware offloading. When using MLAG, the L3 hardware offloading must be disabled.”
But isn´t it disabled when it looks like this? Or is there a different off switch for “L3 hardware offloading”?
[admin@CRS01] > /interface/bridge/mlag/print
bridge: bridge1
peer-port: bonding1
[admin@CRS01] > /interface/ethernet/switch/print
Columns: NAME, TYPE, L3-HW-OFFLOADING, QOS-HW-OFFLOADING
# NAME TYPE L3-HW-OFFLOADING QOS-HW-OFFLOADING
0 switch1 Marvell-98DX8525 no no
1 switch2 Atheros-8227 no no
[admin@CRS01] > /interface/ethernet/switch/port print
Flags: R - RUNNING
Columns: NAME, SWITCH, L3-HW-OFFLOADING, STORM-RATE
# NAME SWITCH L3-HW-OFFLOADING STORM-RATE
0 ether1 switch2
1 R qsfp28-1-1 switch1 no 100
2 qsfp28-1-2 switch1 no 100
3 qsfp28-1-3 switch1 no 100
4 qsfp28-1-4 switch1 no 100
5 R qsfp28-2-1 switch1 no 100
6 qsfp28-2-2 switch1 no 100
7 qsfp28-2-3 switch1 no 100
8 qsfp28-2-4 switch1 no 100
9 sfp28-1 switch1 no 100
10 sfp28-2 switch1 no 100
11 sfp28-3 switch1 no 100
12 sfp28-4 switch1 no 100
13 sfp28-5 switch1 no 100
14 sfp28-6 switch1 no 100
15 sfp28-7 switch1 no 100
16 sfp28-8 switch1 no 100
17 sfp28-9 switch1 no 100
18 sfp28-10 switch1 no 100
19 sfp28-11 switch1 no 100
20 sfp28-12 switch1 no 100
21 sfp28-13 switch1 no 100
22 sfp28-14 switch1 no 100
23 sfp28-15 switch1 no 100
24 R sfp28-16 switch1 no 100
25 switch1-cpu switch1 100
26 switch2-cpu switch2
The problem seems to have been related to the bond.
If I don’t do the MLAG synchronisation on the bond, it works.
