MLAG Issue with LACP Ports on HP 5130 Stack
I’m currently facing an issue with my MLAG setup consisting of a CRS317-1G-16S+ and a CRS309-1G-8S+. The MLAG is connected to an HP 5130 stack through two 10Gbps cables, and LACP is configured on the HP side.
Initially, everything appears to be working correctly. However, after some time, I’ve noticed that the management IPs of both Mikrotik devices start dropping approximately half of the incoming packets. In order to regain full access to these devices, I need to disable one of the two links.
Has anyone experienced a similar issue with their MLAG setup, or can you offer any suggestions on how to resolve this problem? Any advice would be greatly appreciated.
Thank you in advance.
I’ve seen this, I’m moving to only running MLAG on edge switch pairs.
An MLAG bond connected to another MLAG bond on another switch was a recipe for disaster.
