MLPPP MTU testing...
Hi
we are experiencing some really strange MLPPP situations with RouterOS:
we set MRU = 1470 and MRRU=1500 we get an mlppp-interface-mtu=1480
we set the interface mtu for the ethernet-interfaces carrying the ppp-streams to MTU=1520
no special mtu/mru/mrru settings in mlppp-dialer we get a nominal MTU=1500 (good), but:
if we try to do a bandwidthtest we have to set the loclal udp size to 1498 to get it working fine.
suggestion from MT-support: mlppp takes 12-bytes-overhead, we should accomodate, ok,
we set the ethernet-mtu to 1522, we get a dialer MTU=1502, in the end we always get it
two byte wrong.
we set things to default (interface-mtu=1500, mlppp-dialer no settings), we get another
mlppp-interface-MTU at 1480, well what the heck, of course local udp size has to be
cecreased to 1478.
if we do these very same bandwidth tests on a single-pppoe-connection - everything is fine
the default values of the bandwidthtest work fine, as well as when we seht the local
udp-tx-size to 1480 - all is fine.
we first saw this phenomenon on a ccr2004 box (ROS 6.46.8, 6.47.9, 6.48.1),
but after some further probing I guess this is not a specific model but rather a
fundamental thing that is happening here (tested also on rb2011,3011).
we reached the point of total no clue.
could anybody enlighten us?
thx
hk
Most tutorials recommend MRI to be set at 1600
MRI?
