Mobile App unable to connect with RADIUS credentials - wrong username or password
Hello. The Android Mobile App (com.mikrotik.android.tikapp) is unable to connect with RADIUS credentials - wrong username or password. I can use the iOS app to connect without any isues.
Somehow the mobile app is treated differently.
Winbox+WebFix:
Authentication Details:
	Connection Request Policy Name:	Use Windows authentication for all users
	Network Policy Name:		MikroTik Login
	Authentication Provider:		Windows
	Authentication Server:		XXXXX
	Authentication Type:		MS-CHAPv2
	EAP Type:			-
	Account Session Identifier:		-
Mobile App
	Network Policy Name:		-
	EAP Type:			-
	Logging Results:			Accounting information was written to the local log file.
	Reason Code:			16
	Reason:				Authentication failed due to a user credentials mismatch. Either the user name provided does not map to an existing user account or the password was incorrect.
I can log in via WebFig from mobile also, but that sorta negates the Mobile App usability.
Local admin accounts are not affected.
NO there is NO typo in password.
Another thing worthy of note might be that the Mikrotik Home app connects just fine. So definitely a bug.
SUP-92201
Same issue here been talking with support since two weeks without any resolution.
Support case 91237
We were able to repeat reported issue with the latest TikApp/RouterOS, we will try to fix the issue shortly.
