Mobile clients unable to connect to either SSID
Hi there, I am both new to this forum and a newbie in the MicroTik world. We just rolled out a MikroTik wireless network for a client with 2 WLC’s and 12 Ap’s. The devices are fairly old ones. They contain 2 SSIDS, one for local LAN access that uses Radius authentication, and the other for Guest with internet access only.
Currently, laptops are able to connect to the SSID’s, however, it seems that no mobile devices at all are able to connect. On Guest, it asks for a username and password (although I believe I only configured it to use a passphrase) and on the LAN one, radius does not work at all.
Is there some special settings I need for the mobile devices? I am using WebFig. Also, why would the Guest be asking for a username?
Please help!
Thanks,
Jim
