So i put together a setup in my country house to have a proper internet connection (no ISP provides cables here).
So i put together a setup involving:
- 1 x SXT LTE
2 x HAP ac lite
2 x RB260GSP Switches
The network topology is as follows:
Switch A → 1 port → SXT LTE
Switch A → 2 port → Switch B
Switch A → 3 port → HAP ac lite (A)
Switch B → 1 port → Switch A
Switch B → 2 port → HAP ac lite (B)
SXT is the main router providing DHCP for the whole network. Every device is in the same ip range.
So what is the problem is the problem is that when you browse something on the web with a mobile phone or tablet it just hangs. Pages wont load etc. Then all of a sudden pages start to load and then freeze up again. Laptops do not show this problem.
Now very weird is that both AP’s cannot ping 8.8.8.8, it will show a timeout.
ping www.google.com will show, could not get answer from dns server.
AP’s are both on Router OS version 6.43.12, also is the SXT.
Please i don’t understand the AP’s setup is so basic that i don’t understand how it’s not working.
SXT is on a factory default setup.
Also SXT RSRP is -60dB. Ping from SXT to 8.8.8.8 or google.com works like a charm.
I have attached my config files as well.
PS: For this thread purposes i have changed the name of SSID and PW and AP names on the config files.
sxt_lte_conf_out.txt (3.97 KB)
house_conf_out.txt (2.72 KB)
sauna_conf_out.txt (2.18 KB)
