Mode button Script Switching
Hi guys, I know that there have been quite a few topics on this, however I just have not been able to make it work, so any help is greatly appreciated.
We use the Mikrotik mAP2nd to help us install Fixed Wireless Access equipment. The mAP powers the radio equipment and the engineer can then access the equipment on their mobile device over the mAP WiFi.
We now want to use it to install a Mikrotik SXT LTE6 device as well as the device above. Rather than purchasing a second unit for these installs I was hoping that I would be able to select between 2 scripts using the mode button.
I have added the 2 separate scripts into Script List and I have tried several commands to get the mode button to switch between the two (mainly what I have found on here)
The previous configuration needs to be deleted and the new script run when the button is pressed as they are completely different.
Does this sound possible? Am I just being a noob? My brain is about to explode and I could really use some guidance!
Cheers
Andy
If you want a solution ready to go try Mode button with multiple presses.
